po90260
Oct 03, 2021Aspirant
WNDR3700 changing from wireless to wired (radio off)
Need to know how to switch back and forth from wireless to wired and back using a wired only PC running Win 7.
Oct 06, 2021Guru - Experienced User
it should
po90260
Oct 07, 2021Aspirant
OK, I'll play around will wps
but
I still can't login to my router using www.routerlogin.com or 192.168.1.1 on my wired PC.
- plemansOct 08, 2021Guru - Experienced User
what modem/gateway is it connected to?
Have you checked to see what its IP address is?
