jjmediaman's avatar
jjmediaman
WNDR4300 Upstream Qos killing internet speed
WNDR4300 - Discovered that I was only getting 9Mbps downstream. Disabled Upstream QOS and it shot up to 50 Mbps. Is there a solution for this other than leaving it disabled? Is there a firmware or ot...
  • ElaineM's avatar
    Sep 03, 2015
    Hi jjmediaman,
    Welcome to the community!
    Did you set some QoS rule? What was set on your Uplink Bandwidth? Have you tried setting a different value under the uplink bandwidth?
    Try around 85% of your uplink bandwidth and see if it will make any difference.
    Looking forward to your response.
