BORIS48's avatar
BORIS48
WNDR4500 connect TV
WNDR 4500 V1.0.1.46_1.0.76 Hi, firends! Help with a problem. I have houses local network: Connection: 1) The router is connected to TV on Ethernet, the laptop (windows10) to TV on WIfi. The netw...
  • BORIS48's avatar
    BORIS48
    Feb 11, 2018
    The problem is solved today. It was necessary to pull out RG-45 from the TV :)
    Thanks, subject it is closed.
