dustybin's avatar
dustybin
WNR 2200 should I update from V1.0.1.68_RANDOMNTPPORT?
I previously had problems using an NTP server behind this router and Netgear kindly provided me with the subject modified firmware.  Can you tell me if the modofication was incorporated into the late...
  • dustybin's avatar
    dustybin
    Dec 21, 2015
    OK - thanks.  I'll try that when I get a chance, although it could be a while as I think the file may be on my old machine.
    All the best - thanks again.
