Bob-NG
Oct 28, 2017Aspirant
WNR2000V5 with version 1.0.0.12 firmware
I have a WNR2000V5 router that is unable to take any firmware upgrades. It is a 1.0.0.12 The Netgear website proclaims "1.0.0.18" as the initial release, so what do I have? Is this the reason w...
- Nov 18, 2017
The replacement router arrived today. It was loaded with 1.0.0.34 firmware and happily took the update to 1.0.0.58.
My problem is solved, though I never found out how I ended up with pre-release version of the firmware
I guess it doesn't matter now.
Bob-NG
Nov 07, 2017Aspirant
That article pertains to the WNR2000V4.
Did you send me the correct link?
ElaineM
Nov 08, 2017NETGEAR Employee Retired
Yes, can you try the same steps for your version?
- mannynaberNov 10, 2017Aspirant
None of the "fixes" mentioned work, I have had the exact same issue with no way of upgrading firmware. Please help
