mike_coreit
Jul 03, 2023Aspirant
WNR2200 DHCP Options
Hi I have a WNR2200 wireless router which I am using as an access point. There seems to be an issue after a few hours the DNS stops working, however if I use the DNS of our main router (WAN) that wo...
- Jul 03, 2023
It's ok I thought what would be the case initially. I'll figure something out 🙂
michaelkenward
Jul 03, 2023Guru - Experienced User
Connected to what?
There seems to be an issue after a few hours the DNS stops working, however if I use the DNS of our main router (WAN) that works fine.
Is there any way to change this in the DHCP options?
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
What actually happens when "the DNS stops working"?
The WNR2200 dates from 2010. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware.
It does not support 5 GHz wifi.
mike_coreit
It is connected to another router for internet access. While I am using it as an access point it still in router mode.
When the issue occurs it just seems that the Netgear cannot resolve any DNS requests, but pinging IP addresses work fine, also does manually changing the DNS on the client.
I also updated to the latest firmware 1.0.1.102 but this didn't make any difference
- michaelkenwardJul 03, 2023Guru - Experienced User
What does that mean? The WNR2200 is in router mode? It can't be a router and access point at the same time.
With two routers you can run into problems.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
I see no indication on the manual for the WNR2200 that it has a built-in AP mode. Maybe it is too old. This could be why you see those problems. There may be a way to get around that.- mike_coreitJul 03, 2023Aspirant
Yes it is essentially double NAT, with both private networks having different IP ranges so they can still communicate. It has been this way for 8 years and my client only called me out a few days ago so it's a mystery
All of a sudden we have a completely different picture.
Your original description was hopelessly inaccurate. Your ancient equipment is not fit for purpose.
You are on your own here.
