sixpiece's avatar
sixpiece
Would like to enable Telnet for R6200
I tried Port Forwarding, and Port Forwarding Telnet.    I tried some of the tools designed for Windows and a C program and a python script and a TelnetEnable1 and a TelnetEnable2 for Windows tools....
  • antinode's avatar
    Feb 14, 2021
    > Would like to enable Telnet [...]
       Why?
    > [...] for R6200
       Firmware version?
       If you want to Telnet _into_ the R6200, then port forwarding won't
    help.
    > I tried some of the tools [...]
       "tried" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > I tried the local host, local host and the specific host [...]
       I don't know what any of that means.
       Telnet access to Netgear routers is not a supported feature, and it
    seems to have disappeared from recent firmware versions on models where
    it had worked previously.
       Possibly interesting:
          https://community.netgear.com/t5/x/x/m-p/1813948
