OdetteJaycock
Dec 13, 2017Aspirant
ReadyCLOUD App for Android & Apple OS
Hi We've installed the Apple OS version of the ReadyCloud app to test if this is an option for working on documents remotely. We've confirmed we have the lastest OS is on the device and we have ...
- Dec 17, 2017
Unfortunately, you have posted in a wrong board, I will be moving your post to the appropriate board to get community members and moderators in that board read your concern.
Regards
Marc_V
Dec 13, 2017NETGEAR Employee Retired
ReadyCloud can allow a user to add, change and delete files on the storage system by giving them Read/Write access. Please see ReadyCloud Permissions
You mentioned office viewers for MS Word and Excel, if you have not installed MS Office it will not let you make any changes the document.
But you opened with MS Word and Save as but you still cannot edit the document?
If you have MS Office then you might need to recheck the permissions you have set for the remote user that you are using for testing. The permissions set should be the same with Android devices.
Please check here for allowing permissions on ReadyCloud.
Hope this helps!
Regards
