naveen555's avatar
naveen555
ReadyDLNA not showing files
Hi ReadyDLNA used to work on my router. I recently changed the folder structure and also upgraded the firmware to the latest one (V1.0.4.8_10.0.77). Now the files can be seen using a computer file b...
  • DexterJB's avatar
    DexterJB
    Sep 28, 2017
    Hi naveen555,
    Please try using the default settings and check if the issue persists. You can also try reconfiguring the router instead of re-loading the config file.
    Dexter
    Community Team
