naveen555
Sep 02, 2017Aspirant
ReadyDLNA not showing files
Hi ReadyDLNA used to work on my router. I recently changed the folder structure and also upgraded the firmware to the latest one (V1.0.4.8_10.0.77). Now the files can be seen using a computer file b...
DexterJB
Sep 25, 2017NETGEAR Moderator
Hi naveen555,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
naveen555
Sep 25, 2017Aspirant
Hi Dexter
Thanks for the follow up. I did try to reset the router to factory default, but I backed up the config and then re-applied it. The problem still exists. Not sure what's going on.
Thanks
Naveen
