SarastroSaruman
Mar 28, 2016Tutor
ReadyDLNA visible but access denied
Hi there, I have a 1TB external drive connected to my router. I can access the drive as a network drive from all PCs over WiFi without any problems. - but I can't access the drive as a media serv...
- Apr 06, 2016
Hi SarastroSaruman,
NETGEAR routers can handle 25000 media files and 10000 files for iTunes.
Dexter
Community Team
SarastroSaruman
Apr 05, 2016Tutor
Hi Dexter,
Thank you for your reply.
Yes I have tried it with a USB stick and it worked. I have then plugged the external disk into my computer and have deleted the folder (.ReadyDLNA)
This worked in so far as all my devices can no access the media server again. The problem is still not completely solved however, as now it does not show me all the folders and no music and no videos. Only photos are shown correctly.
Is it possible that the R6300v2 only can process a certain amount of data? I have 400GB on the harddisc now - maybe the router can't process that amount of media data???
Thank you,
Florian
DexterJB
Apr 06, 2016NETGEAR Moderator
Hi SarastroSaruman,
Dexter
Community Team
- SarastroSarumanApr 08, 2016Tutor
Well there we have the problem... My photos alone are 25.000 - that's why it only shows me pictures and no music and no videos.
It is rather annoying that I have to buy a new router after just one year.
Do you have other routers that can handle conserably more media files or do I have to buy another brand?
Thank you
- DexterJBApr 13, 2016NETGEAR Moderator
Hi SarastroSaruman,
Most of the latest NETGEAR routers max out on that due to the MiniDLNA version they use.
Dexter
Community Team
- SarastroSarumanApr 14, 2016Tutor
Thank you Dexter.
I have bought a synology NAS to solve the problem.
