fiedler
Apr 11, 2017Guide
ReadyShare can't find USB drive
Have 2 laptops connected to Readyshare. Been working OK. One laptop had a hard drive die, so I replaced and reloaded win10. The bad drive would still let me get files off of it, so I didn't use Rea...
- Apr 12, 2017
OK, Found the solution.
Uninstall the latest version of Genie. It is junkware.
Reinstall the pervious version. All is good.
fiedler
Apr 12, 2017Guide
- ElaineMApr 13, 2017NETGEAR Employee Retired
What Genie version were you using previously and what version that made it worked?
- fiedlerApr 18, 2017Guide
Your software does not display version numbers, so I have no idea.
My admin interface suggested updating to the newest version, and that's when the trouble began.
I found a 2.428.0 Genie version from 2016 in one of my folders. Maybe that is the one I went back to.
