fiedler's avatar
fiedler
Guide
Apr 11, 2017
ReadyShare can't find USB drive
Have 2 laptops connected to Readyshare. Been working OK. One laptop had a hard drive die, so I replaced and reloaded win10. The bad drive would still let me get files off of it, so I didn't use Rea...
  • fiedler's avatar
    Apr 12, 2017
    OK, Found the solution.
    Uninstall the latest version of Genie. It is junkware.
    Reinstall the pervious version. All is good.
