Kkk1's avatar
Kkk1
Follower
Dec 05, 2016
Readyshare cloud registration -
Hi Netgear / All,
Is there a way to register my router to a https://readyshare.netgear.com/login/index.html?err=1 ? Seems service is no longer supported and I cannot add cloud account.
I have tried to create a new account under (newer) link:
http://readycloud.netgear.com/client/index.html#page=access
but when trying to discover my router in Genie (1st provided my new cloud credentials - failed;  then tried with netgear account credentials - also genie router registration failed) it fails.
Would you have any hints 4 me please?
  • Welcome to the community, Kkk1
    Unfortunately, ReadSHARE is no longer available for new registration. The only way to access your files over the Internet is to use HTTPS or FTP.
    ReadyCloud feature is only available on selected model numbers.
    Which NETGEAR routers support ReadyCLOUD?
1 Reply
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
