josh31
May 08, 2023Aspirant
readyshare does not work with ventura
Hello, I have a problem installing the utility correctly on Mac OS 13 Ventura. I tried with version 3.1 I perform the installation, the installation utility asks me to restart, I restart. At star...
josh31
May 19, 2023Aspirant
After installation of readyshare on macbook, OS: ventura I get error message that installation is incomplete.
Result is that readyshare does not work and therefor unable to recognise any usb printer attached to my router.
Anybody has the solution for this?
michaelkenward
May 20, 2023Guru - Experienced User
- josh31May 21, 2023Aspirant
Thanks for a referral, but of course i checked this already. Do you also have referral to actual solution?
- michaelkenwardMay 21, 2023Guru - Experienced User
You didn't say that you had searched for solutions. (Many people don't.) Anything on the subject is likely to be there. If it offers no clues that you can pursue, then there probably isn't much relevant expertise here.
Apple is famous for changing things in unexplained ways that have unfortunate knock-on affects. The only people who can help are probably Apple experts, who are thin on the ground here.
Apple broke your ReadySHARE access. And Netgear hasn't done anything to update ReadySHARE in quite some time.
Thanks for the reply. Understood, but this also means that none of the newer netgear routers will work with apple and readyshare since all new routers use the same readyshare app. I hoped it would be interest of netgear as well to get this solved.
Thanks in any case.
