conradmetz
Oct 04, 2015Aspirant
ReadySHARE flash drives disappeared from network
Previously I could access the flash drives connected to my WNDR4500(v2) by clicking on "Network" under "Computer" on my Windows 7 desktop. As of yesterday, the flashdrives have disappeared at that lo...
- Oct 12, 2015
It turns out that the solution is really much simpler. Instead of approaching the situation through Computer/Network, simply enter Netgear Genie, click through the ReadySHARE choices, and click on the router address. When the flashdrive appears, right click on it and select "Map network drive." Select any available drive letter and immediately the flash drive becomes available under Computer.
ElaineM
Oct 05, 2015NETGEAR Employee Retired
Welcome to the community, conradmetz
The Windows Update might have changed some settings.
You may want to re-mapped the drive by adding the Network Location under "Computer".
See this link on how to map the drive again.
- conradmetzOct 05, 2015Aspirant
I tried to follow the procedure for mapping a network drive, but got stymied by the terminology. I know my flashdrive drive letters (U and T) but what does "folder" mean in this context?
- ElaineMOct 06, 2015NETGEAR Employee Retired
If ever you want to specify a specific folder inside the drive then you may do so.
That's what the folder mean.
