Rebel792
Sep 23, 2016Tutor
Readyshare is not accessible.
Running windows 10, and had a major update yesterday and lost all my Network connections. was able to remap all my drives except my readyShare Drive. every time I try to remap it. I get an error ...
- Sep 24, 2016
Found a solution:
go into user account in control panel
if you're in windows 10 select manage your credentials this will open 2 options
web credentials and windows credentials
head to windows credentials and add a new windows credential
enter the location of the drive \\readyshare on the first line
your windows user name in the second line
your windows password in the third line
and you're done, you should see the drive under network and be able to access it as before
good luck
Rebel792
Sep 24, 2016Tutor
Found a solution:
good luck
hhazeley
Sep 24, 2016Initiate
Thanks.
For me i know its not the computer because i have Windows 10, Windows 7, Server 2008 and Server 2012, none can access share or router interface. The funny thing is if i reboot the router it works for about 3 mins then nothing. Everything else works fine, i can browse the internet from machine and machines can see each other on the network.
