Rebel792
Sep 23, 2016Tutor
Readyshare is not accessible.
Running windows 10, and had a major update yesterday and lost all my Network connections. was able to remap all my drives except my readyShare Drive. every time I try to remap it. I get an error ...
- Sep 24, 2016
Found a solution:
go into user account in control panel
if you're in windows 10 select manage your credentials this will open 2 options
web credentials and windows credentials
head to windows credentials and add a new windows credential
enter the location of the drive \\readyshare on the first line
your windows user name in the second line
your windows password in the third line
and you're done, you should see the drive under network and be able to access it as before
good luck
ajljml
Oct 02, 2016Aspirant
I just got a Surface Pro 4 with Windows 10. I am able to log into the router in a browser using 192.168.1.1 and in there I can see the external drive I have connected to the router USB. I am also able to access it on my phone (S6). However, when I downloaded the netgear genie adn the Ready Share Vault app to the computer, in addition to being super tiny and hard to see, they do not show any ready share devices attached. If I try to go to \\Readyshare in a browser window, it says Hmm, we can't reach this page. I added a certificate and tried using my windows u.n./password. i also tried my router admin password. I have taken them off and reinstalled them multiple times, but I can not get it to work. Please help me figure out what I am doing wrong.
