Rebel792
Sep 23, 2016Tutor
Readyshare is not accessible.
Running windows 10, and had a major update yesterday and lost all my Network connections. was able to remap all my drives except my readyShare Drive. every time I try to remap it. I get an error ...
- Sep 24, 2016
Found a solution:
go into user account in control panel
if you're in windows 10 select manage your credentials this will open 2 options
web credentials and windows credentials
head to windows credentials and add a new windows credential
enter the location of the drive \\readyshare on the first line
your windows user name in the second line
your windows password in the third line
and you're done, you should see the drive under network and be able to access it as before
good luck
ajljml
Oct 04, 2016Aspirant
I ended up putting \\192.168.1.1 in the windows certificate with the netgear admin user name & password and that worked for me
- ElaineMOct 04, 2016NETGEAR Employee Retired
- AlpineKid66Dec 06, 2016Guide
This did not work for me.
