Rebel792's avatar
Sep 23, 2016
Readyshare is not accessible.
Running windows 10,  and had a major update yesterday and lost all my Network connections.  was able to remap all my drives except my readyShare Drive.   every time I try to remap it. I get an error ...
  • Rebel792's avatar
    Sep 24, 2016
    Found a solution:
    go into user account in control panel
    if you're in windows 10 select manage your credentials this will open 2 options
    web credentials and windows credentials
    head to windows credentials and add a new windows credential
    enter the location of the drive \\readyshare on the first line
    your windows user name in the second line
    your windows password in the third line
    and you're done, you should see the drive under network and be able to access it as before
    good luck
