Rebel792
Sep 23, 2016Tutor
Readyshare is not accessible.
Running windows 10, and had a major update yesterday and lost all my Network connections. was able to remap all my drives except my readyShare Drive. every time I try to remap it. I get an error ...
- Sep 24, 2016
Found a solution:
go into user account in control panel
if you're in windows 10 select manage your credentials this will open 2 options
web credentials and windows credentials
head to windows credentials and add a new windows credential
enter the location of the drive \\readyshare on the first line
your windows user name in the second line
your windows password in the third line
and you're done, you should see the drive under network and be able to access it as before
good luck
MrEugeneKrabs
Nov 05, 2016Tutor
If we are talking here Windows 10. The other computer might have had the same update that you got and therefor you you both lost that specific functionality. If that is the case this thread or the links tho other threads should solve your problem... as it did with me.
If we are not talking Windows 10... you are propably with the wrong thread :-(
MardnS
Nov 07, 2016Aspirant
Can anyone then steer me in the right direction for WIndows 8.1 fixture of the issue?
