BenZ
Jan 02, 2017Aspirant
ReadySHARE not permanent visible in windows 10 explorer, R7000
Hello
I'am able to 'see' the two USB drives attached to my R7000 by 'running the \\readyshare command'.
I have to re-run \\readyshare command each time I open windows explorer while in the past I saw the USB drives permant in windows explorer.
This is inconveniant for making back-ups of those usb drives e.g.
thanks for any help
Ben
Welcome to the community, BenZ
Did you try resetting the router?
I suggest that you try to safely remove the drives then factory reset the router then reconnect the drives and verify if the problem continues.
1 Reply
- ElaineMNETGEAR Employee Retired
