did123445
Apr 04, 2017Aspirant
READYSHARE not recognizing USB
I unpluged my usb device to add some data, after re-pluging it, my router wont recognize it! I have tried to reboot the router, erase files from the drive, but no luck at all... what may i do in this...
- Apr 04, 2017
ok so after quite a while, the router recognized it and added it as normal... seems you have to be very patient...
crappy
Apr 12, 2017Aspirant
will not turn on usb lite...any of software results wonr work...is router defective...printer works to computer but router will not recognize printer
