haroldappel
Jul 14, 2019Tutor
ReadySHARE Printer Utility Version 2.36 failure
Very frustrated. Trying to get readyshare printing to work on my AC 1750 R6400v2 router using my Macbook Pro running MacOS 10.14.5. I run v 2.36 and it seems to install but when I do the required restart I get the messsage that installation is incomplete, reinstall. I tried several times and gave up in disgust. Tried using the MyNetgear portal but it said I had no registered products. I had registered. Tried and it said something went wrong. This might be my last Netgear purchase.
I gave it accessibility permission in system preferences, security.
- DexterJBNETGEAR Moderator
Good to hear this, thanks!
