ejbpesca
Jan 28, 2023Aspirant
ReadyShare server down?
I have done all the connecting instructions to use a USB drive on my Netgear Router. When I attempt to access the server I get a message it is not accessible. I've tried for a week to access it wit...
ejbpesca
Jan 29, 2023Aspirant
Model. C630
Macbook Air M2 Ventura
Using Connect to Server under GO as instructed I successfully reached smb://readshare once, now it I get the message it is not available.
I am trying to drag/drop a screen shot of the path but the image will not attach.
I use Netgear Genie. It shows I am set to go to used the USB drive in the router.
The USB drive is a 32 GB USB 3 formatted to one of the compatible readyshare formats.
michaelkenward
Jan 29, 2023Guru - Experienced User
ejbpesca wrote:
Model. C630
Do you mean C6300? If so, does it say V2 on the label? If not it is V1.
At least we know that we can ignore the firmware on the device., It is beyond your control.
No idea what "Connect to Server under GO as instructed" means.
You did not mention that in your first message.
It means that you are using the Media server on whatever modem/router you own. It is not the same as ReadySHARE for USB storage.
The media server – and how it works – depends on your media player.
I don't know what that means.
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
Your various images seem to be related to whatever you are using as a media player on the Macbook Air M2 Ventura. I'm afraid that is down to the Macbook.
- ejbpescaJan 29, 2023Aspirant
It is a C6230 with no V2 on the label.
This is how Netgear instructions say to access the usb:
On a mac open Finder, Select GO, under go Select Connect to server and enter smb://readyshare.
That will open once I enter smb://ready share it asks I will allow the server to access files on my Mac. I click allow and get this:
- michaelkenwardJan 29, 2023Guru - Experienced User
OK. A Mac thing. So I am out of my depth.
The fly in the ointment here could be that Apple keeps changing things in way that break stuff like ReadySHARE.
In Windows there is no need for anything to use a router's DLNA media server, you just fire up a media player and it finds the media files.
All I can suggest it this:
Search - NETGEAR Communities – ReadySHARE DLNA mac
