Tibbee
Nov 20, 2022Aspirant
ReadyShare Unavailable without Internet Connection - WHY?
I'm obviously not a tech guru - but it seems incredibly moronic that, given the R6400 is the router - WHY that it can't route traffic directed to ITSELF when the Internet is down? Why does it so badl...
michaelkenward
Nov 21, 2022Guru - Experienced User
That's a bit of a random brain dump that is hard to follow.
Can you take us through what you are doing and where it goes wrong?
Edit out the bits that don't add to the story and add details that might help someone to reproduce what you are doing..
We don't know what router you are playing with, what firmware its on it, or what modem/gateway/ONT sits between it and the Internet.
- TibbeeNov 21, 2022Aspirant
Very sorry for the sarcasm - I was incredibly frustrated last night.
When my Internet goes down, the smb://readyshare/USB_Storage root no longer allows access to the USB drive attached to my router.
However, if I switch to smb://192.168.1.1/USB_Storage, then that access is restored - for instance, with the VLC app on my FireStick.
This inability to reach readyshare affects all of my devices. My Mac also can't access readyshare - but it can still access via the IP? 192.168.1.1.
My Router is
R6700v3
Firmware Version
V1.0.4.128_10.0.104Again, I obviously have no clue how any of this works - but it would seem more logical that the Router wouldn't require the Internet to identify itself?
Thanks very much for any advice on how I might get around the issue?
- michaelkenwardNov 22, 2022Guru - Experienced User
Irony, sarcasm even, is fine, but it has to make sense.
You didn't answer the question about the modem/gateway/ONT. Make and model number
It could be important.
- TibbeeNov 22, 2022Aspirant
I'm not certain as to what you're requesting - but I will VERY HAPPILY follow any and all instructions you might provide?
AC1750 Smart Wifi Router
Model: R6700v3
It's connected via ethernet cable to an
Arris SURFboard SB6141
Router InformationHardware Version R6700v3Firmware Version V1.0.4.128_10.0.104GUI Language Version V1.0.4.122_2.1.38.1LAN PortMAC Address 6C:CD:D6:ED:26:7DIP Address 192.168.1.1DHCP OnInternet PortMAC Address 6C:CD:D6:ED:26:7EIP Address xxx.xxx.xxx.xxx - not sure if that should be shared?Connection DHCPIP Subnet Mask 255.255.255.0Domain Name Server 24.245.113.16624.245.113.167And, again I apologize for the sarcasm - I was just trying a different approach, given this previous thread was left unanswered?Readyshare unavailable on LAN without an internet ...
Also, if I've overshared "secure" info that I shouldn't have - MAC Address, etc? - please let me know - or if you can, just edit it out?
THANK YOU SO VERY MUCH!!!!!!
