nordman
Oct 09, 2018Tutor
ReadySHARE USB Printer broken after updating to OSX 10.14 Mojave
I upgraded my macbook pro to OSX 10.14 Mojave and now I can't get Readyshare USB Printer to work. I keep getting the same error that it could not complete installation. It previously worked on 10.13....
- Dec 19, 2018
Hi community,
I have had the same porblem but get it solved yesterday. In the web I have found following:
"Fixed it by:
1. Uninstall the Control Center app
2. Mac System Preferences > Printers&Scanners > Reset Print System (remove your printer by pressing the "-")
3. Reboot
Now Mac OS Mojave (Mac System Preferences > Printers&Scanners >"+") recognizes printer networked through Netgear router.
It works.
nordman
Oct 09, 2018Tutor
Here's is the error I get.
- schumakuOct 10, 2018Guru - Experienced User
Christian_R ChristineT please. Apple as well as Microsoft offer early access to developer or preview versions of new OS. Beyond me on why Netgear QA is unable to maintain a test cycle potentially triggering their engineering to address things in time - before the new OS are released to the public. This is also a job for the product manager. But of course, I've sent them all to Tasmania before. 8-/
- Jonathan42Oct 10, 2018Initiate
Same problem after the Mojave update!
- agpotOct 16, 2018Initiate
Same problem. Can you post the solution here as soon as it's available?
