nordman
Oct 09, 2018Tutor
ReadySHARE USB Printer broken after updating to OSX 10.14 Mojave
I upgraded my macbook pro to OSX 10.14 Mojave and now I can't get Readyshare USB Printer to work. I keep getting the same error that it could not complete installation. It previously worked on 10.13....
- Dec 19, 2018
Hi community,
I have had the same porblem but get it solved yesterday. In the web I have found following:
"Fixed it by:
1. Uninstall the Control Center app
2. Mac System Preferences > Printers&Scanners > Reset Print System (remove your printer by pressing the "-")
3. Reboot
Now Mac OS Mojave (Mac System Preferences > Printers&Scanners >"+") recognizes printer networked through Netgear router.
It works.
likessailboats
Oct 22, 2018Tutor
I am having this same problem. Will NetGear be updating the ReadySHARE printer utility for macOS 10.14?
Version 2.40 of the utility was the fix for macOS 10.13 and it was very late.
Thanks.
nordman
Oct 22, 2018Tutor
The "tech support" person that called kept saying over and over, "we have people who say ReadySHARE USB works with 10.14." I kept saying that it doesn't, and no one else has had this experience. Just worthless "support". Last Netgear product I'll ever buy
