nordman
Oct 09, 2018Tutor
ReadySHARE USB Printer broken after updating to OSX 10.14 Mojave
I upgraded my macbook pro to OSX 10.14 Mojave and now I can't get Readyshare USB Printer to work. I keep getting the same error that it could not complete installation. It previously worked on 10.13....
- Dec 20, 2018
Hi community,
I have had the same porblem but get it solved yesterday. In the web I have found following:
"Fixed it by:
1. Uninstall the Control Center app
2. Mac System Preferences > Printers&Scanners > Reset Print System (remove your printer by pressing the "-")
3. Reboot
Now Mac OS Mojave (Mac System Preferences > Printers&Scanners >"+") recognizes printer networked through Netgear router.
It works.
bluzfanmr1
Nov 08, 2018Tutor
Same thing happened with High Sierra (lots of forum posts on here). It took forever for Netgear to update the USB Control Center software.
DekWatson
Dec 04, 2018Aspirant
Same issue here, just setup Orbi network and then added printer...
- phazeiDec 13, 2018Initiate
Same here :smileymad:
- HaptDec 20, 2018Initiate
Hi community,
"Fixed it by:
3. Reboot
It works.
- bluzfanmr1Dec 20, 2018Tutor
This does NOT work unless the printer is connected to the Mac, hence defeating the purpose of using the usb connection on the router via the USB Control Center.
- likessailboatsDec 21, 2018Tutor
The ReadyShare utility is not needed to connect to the printer via WiFi. However the utility is needed for scanning, opening the manufacturer's printer utility, and maybe more.
This method has always worked for me with Mac OSX and now MacOS. I uses "Bonjour" and each print request is a bit slow to get going. But it works for printing.
The problem I have is that the Scan function seems to be unavailable and the manufacturer's printer utility can't connect to the printer.
The Netgear ReadyShare Printer Utility solved these problems.
In my experience, it takes a while for Netgear to update this utility after a new Mac OS version is released.
In the meantime I have to carry my laptop to the printer and plug it in to the USB port to scan or run tests, see ink levels, etc.
