nordman
Oct 09, 2018Tutor
ReadySHARE USB Printer broken after updating to OSX 10.14 Mojave
I upgraded my macbook pro to OSX 10.14 Mojave and now I can't get Readyshare USB Printer to work. I keep getting the same error that it could not complete installation. It previously worked on 10.13....
- Dec 19, 2018
Hi community,
I have had the same porblem but get it solved yesterday. In the web I have found following:
"Fixed it by:
1. Uninstall the Control Center app
2. Mac System Preferences > Printers&Scanners > Reset Print System (remove your printer by pressing the "-")
3. Reboot
Now Mac OS Mojave (Mac System Preferences > Printers&Scanners >"+") recognizes printer networked through Netgear router.
It works.
mgrinersc
Dec 30, 2018Initiate
I just swapped from the Airport Extreme 2TB to the R7000P AC2300 MU-MIMO router and everything has gone swimmingly up until trying to install the NetGear USB Control Center; I too am getting the dreaded "Installation Not Complete" error. I've done everything I can imagine to get it to install with no luck... I'm no stranger to tech, consumer or commercial networks, NAS, FTP, etc, and humbly consider myself a power user, but nothing is working for me. Even tried the suggested fix on this thread to cover all the bases - nada.
Netgear, help me/us out.
I am running 10.14.2 (18C54) Mojave on the "best" 15" MBP that can be bought from Apple. Also, Bonjour works flawlessly and will let me add the printer via the router on the LAN. For ovious reasons I can't get the AirPrint to function, and, of course, as mentioned above, the USB Control Center.
- bluzfanmr1Dec 31, 2018Tutor
If you have an older printer that doesn't have wifi, you are hostage to the USB Control Center software. Until it is updated for Mojave it won't work. You will be waiting a long time because they are painfully slow in staying on top of this and the wait is unacceptably long. It happened with High Sierra and now Mojave.
Your best bet is to do what I did. Get a new printer with wifi and junk your Netgear stuff. I'm in the tech field and I can honestly say I will never buy or recommend Netgear stuff to anyone going foward.
