darrenlhr
Oct 01, 2017Follower
ReadySHARE USB Printer for macos High Sierra - Installation Is Incomplete
Hi, I am having trouble installing the ReadyShare USB Printer (ReadySHARE USB Printer MAC_V2.36) on macOS High Sierra. Whenever the installation completes and the machines reboots, Netgear USB Co...
- Jan 25, 2018
Hi all,
You can download the new USB Control Center app using the link below.
https://kb.netgear.com/000053245/
Dexter
Community Team
Kneelb4z0d
Nov 13, 2017Aspirant
same problem here,
removed old app reinstalled new app, says installation incomplete. looks like im gonna have to move the laser printer next to my mac so i can print to it. tbh the app hardly ever worked anyway before i upgraded to high constant restarts to get it to print, i need to find a better solution to the problem.. i might just go with another brand as the QOS is messed up on this router aswell
Hawkeye1027
Dec 21, 2017Aspirant
I was having the same problem, having to restart (router, PC, printer - sometimes all 3 at once) just to get the connected printer to print. It showed it was in Ready status, but kept getting printer error messages on my PC. The problem turned out to be my printer USB cable, which is about 15 feet long. Even though it was less than a year old, once I replaced it with an Anker cable of the same length and the problem went away. :smileyvery-happy:
That was a month ago. I now have a new issue - the USB Control Center doesn't want to connect with my printer. I can switch from "Available" status to "Mannually Connected by (PC name)". After 10 minutes it disconnects. :smileyfrustrated: IDK if this was caused by the router firmware update, or the Win-10 update a few days ago, since they were both just a couple of days apart. I'm leaning toward the Win-10 being the culpret, since I was able to print after updating the router.
- RRM855Jan 02, 2018Apprentice
I am still waiting for the ReadySHARE USB Printer utility version 2.4 for Mac High Sierra to be released.
- bobbycee70Jan 07, 2018Tutor
Yeah, still waiting here for Mac iOS 10.13 update too :( I might just opt to purcahse a standalone print server...
It just seems as though this is planned obsolescence - I'm comfortable and aware that drivers update, etc., but this is just a real pain that I can count on long term use.
- chadpattJan 21, 2018Initiate
Instead of using this very poor software, use the built in drivers in OSX. I can by pass this software and directly print to the IP of the router. Follow these steps.
System Preferences> Printers & Scanners
Add a printer
Select IP on the top menu
in the Address box put in the ip of the router
select HP Jetdirect - Socket
in the Use Box, select your printer software
and hit add.
On my setup, it works perfectly and super fast.
