darrenlhr
Oct 01, 2017Follower
ReadySHARE USB Printer for macos High Sierra - Installation Is Incomplete
Hi, I am having trouble installing the ReadyShare USB Printer (ReadySHARE USB Printer MAC_V2.36) on macOS High Sierra. Whenever the installation completes and the machines reboots, Netgear USB Co...
- Jan 25, 2018
Hi all,
You can download the new USB Control Center app using the link below.
https://kb.netgear.com/000053245/
Dexter
Community Team
RRM855
Jan 21, 2018Apprentice
Would that work for non-HP printers? What would happen if you left it at Internet Protocol Printing?
The 2.4 utility does work, it is just that it has to constantly be reconnected upon start-up and if it has been left idle for a while. Do others know a work-around for that problem?
chadpatt
Jan 21, 2018Initiate
Yep, my printer is a Brother Lazer printer. I had no problem printing to it via this method.
- antinodeJan 21, 2018Guru
> select HP Jetdirect - Socket
The protocol (using port 9100) was developed by HP, but adopted much
more widely.
https://hacking-printers.net/wiki/index.php/Port_9100_printing - DexterJBJan 25, 2018NETGEAR Moderator
Hi all,
Dexter
Community Team
