Trich34234
May 22, 2021Aspirant
Really Extreme Lag Spikes... If anybody is willing to help me please do! 2 Years of this...
Hello. For the past year, almost two now, I have been experiencing terrible lag spikes when playing video games. I have tried everything in this world to try to fix it, and the ISP will not help an...
May 22, 2021Guru - Experienced User
what modem/gateway do you have?
do you get the lag spikes if the console is plugged directly into the gateway?
Trich34234
Plugging my console directly into the wifi still does not work. The spikes continue to happen, and I have tried a new router and the same spikes still happen. Look at this video...
https://www.youtube.com/watch?v=0OBAnjwhXys&feature=youtu.be
- plemansMay 27, 2021Guru - Experienced User
Trich34234 wrote:Plugging my console directly into the wifi still does not work.-----wifi isn't a plug in. if your console is connected to the router via ethernet cable, does it happen. The spikes continue to happen, and I have tried a new router and the same spikes still happen. Look at this video...
What modem/gateway are you connected to?
Do the lag spikes happen if you're connecting directly to the modem?
