dsdoyle
Oct 05, 2015Aspirant
Receive "The IP address conflicts with the WAN IP subnet" when making LAN changes
Hello, I have the following devices: Prosafe FVS336Gv3 Router R6300v2 The static IP setting for the LAN on the Prosafe is 192.168.1.1/255.255.255.0 The static IP setting for the WAN on ...
- Oct 05, 2015
Ended up being a DNS setting on the WAN port of the router.
netwrks
Oct 05, 2015Master
Is this what you are trying to acheive?
ISP device<----->NGFirewall<-------->R6300
What device is going to be your DHCP Server?
If you want to run the R6300 in AP mode (no DHCP set on it) and set as an Access Point follow instructions on Pgae 84 You have to set the IP address in the same subnet as your DHCP Server.
