BobLo
Apr 23, 2016Aspirant
Recommendation not to change the SSID
I noticed this statement in the manual: "The default SSID is randomly generated, and NETGEAR strongly recommends that you do not change this setting." They use italics for emphasis. They don't ju...
michaelkenward
Apr 24, 2016Guru - Experienced User
Indeed. Netgear's advice makes no sense.
What are the benefits of sticking with the SSID it provides?
It is the password that matters.
BobLo
Apr 24, 2016Aspirant
I think I may have it now. IIRC, the default SSID is NETGEARnn. I think they strongly want you to advertise the Netgear brand to the users of every Wi-Fi device that's close enough to see your beacons. I'm not impressed by marketing masquerading as technical advice.
