BobLo's avatar
BobLo
Recommendation not to change the SSID
I noticed this statement in the manual: "The default SSID is randomly generated, and NETGEAR strongly recommends that you do not change this setting."   They use italics for emphasis. They don't ju...
  • ElaineM's avatar
    May 03, 2016
    BobLo The recommendation from the manual is to just allow users to easily locate or identify their own routers in case they forgot what it was.
    In any case, I will forward your feedback to the documentation team for review.
    Thank you and have a great day!
