AnneLowe
Mar 31, 2021Aspirant
Recommended 4G Router
Hello, I am looking for a recommendation for a fixed 4G router. It is for a rural property that does not have access to normal broadband facilities. I need to run in excess of 30 smart devices off ...
Mar 31, 2021Guru - Experienced User
Netgear has an orbi router that supports LTE service. Might be worth checking into for your setup. Plus then you can add satellites if you need additional coverage.
