Joel2020
Jul 26, 2020Aspirant
Reconnect to new wifi from Spectrum
I'm have problems with getting connected to new set-up from Spectrum system. Adapter was working fine until new system was installed. I'm having issues getting into entering new password, etc.
- Jul 26, 2020
What are the led's on it doing?
where is it failing in the process?
Any thoughts on updating? thats a 10 year old single band wireless N device.
Jul 26, 2020Guru - Experienced User
Joel2020
When I first try to get it going, I used this link, http://www.mywifiext.com/ . It said that it connected but when I plugged it into to my television, it said that it couldn't connect to my wifi network. Right now, it's connected directly to my wifi system. The power light and the LAN lights are green and solid (no blibking). The WLAN light is off. When I used the wizard, I selected manual. It never gave me the option to identify my network selection or password.
