vojtec
Apr 16, 2021Tutor
Recurring notices to update firmware for WNDR3400V3, But no updates available.
Every day, multiple times during the day I get a notice to update the firmware. After going through the proceedure and selecting "Firmware Update" and "Check" i get a notice "No new firmware version ...
- Apr 19, 2021
What modem is it connected to?
You're a bit out of date, if you manually update it, you should stop getting the notices.
Apr 16, 2021Guru - Experienced User
What actual firmware are you on?
You can manually update the firmware.
https://www.netgear.com/support/product/wndr3400v3
vojtec
Apr 16, 2021Tutor
My current version is V1.0.124_1.0.67. yes I can manually update - but thats not the problem. Its the constant stream of "update available" notices such that I can't tell when there is an applicable update for my router.
- plemansApr 19, 2021Guru - Experienced User
