jerfurth
May 02, 2022Tutor
Red light on AC1750 Model R6400
I have this an older AC1750 - R6400 router and have two devices plugged directly into it. One of the direct plugins has a solid red light although it is working perfectly. How do I eliminate the re...
May 02, 2022Guru - Experienced User
Whats plugged into it? usually the red/amber light indicates its connection is a 10/100mbps and not gigabit.
- jerfurthMay 02, 2022Tutor
Thank you for the reply. I simply ran the cat5e cable directly from the router to a TCL Smart TV rather than using the wifi connection. Everything is working fine, but I am concerned about the red light. Any other insights are greatly appreciated.
- plemansMay 02, 2022Guru - Experienced User
What tv is it?
Most tv's aren't gigabit.
Again, if the device its connecting to isn't gigabit, it connects as a 10/100mbps connection and so will show amber/red.
It is a basic 55" TCL and shouldn't be anything that would cause a problem. I tried several different cables, did a soft reset on the modem etc. I have not tried a hard reset but hesitate to do that as everything is working perfectly. I just have had the red light since I pluged the TV in directly to the modem.
