jerfurth
May 02, 2022Tutor
Red light on AC1750 Model R6400
I have this an older AC1750 - R6400 router and have two devices plugged directly into it. One of the direct plugins has a solid red light although it is working perfectly. How do I eliminate the re...
jerfurth
May 02, 2022Tutor
Thank you for the reply. I simply ran the cat5e cable directly from the router to a TCL Smart TV rather than using the wifi connection. Everything is working fine, but I am concerned about the red light. Any other insights are greatly appreciated.
May 02, 2022Guru - Experienced User
What tv is it?
Most tv's aren't gigabit.
Again, if the device its connecting to isn't gigabit, it connects as a 10/100mbps connection and so will show amber/red.
- jerfurthMay 02, 2022Tutor
It is a basic 55" TCL and shouldn't be anything that would cause a problem. I tried several different cables, did a soft reset on the modem etc. I have not tried a hard reset but hesitate to do that as everything is working perfectly. I just have had the red light since I pluged the TV in directly to the modem.
- plemansMay 02, 2022Guru - Experienced User
Is it not working?
Whats all the lights doing?
What exact light is red?
- jerfurthMay 03, 2022Tutor
Everything is working perfectly but was surprised to see the red light on the port where I plugged the TV into directly. I have another port directly connected which feeds a number of other devices in my home - other TV's & a desktop - rather than utilizing the wifi system. That port is a solid white and I was expecting the port where I plugged in the TV to be the same. Perhaps it is normal.
Thanks for the help.
- michaelkenwardMay 03, 2022Guru - Experienced User
What is this "modem"?
In general, LEDs for Ethernet connections follow the same convention. Modems, routers, switches they are usually the same.They are speed indicators.
As has been said already, several times, the red (amber) Ethernet LEDs on R6400 tell you how fast a device is connected to the router on that LAN port.
Here's what t says in the manual:
"The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections."
Page 11.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.- jerfurthMay 03, 2022Tutor
Thanks for the help and I have looked over page 11 of the manual. It appears the red light is normal.
