jerfurth
May 02, 2022Tutor
Red light on AC1750 Model R6400
I have this an older AC1750 - R6400 router and have two devices plugged directly into it. One of the direct plugins has a solid red light although it is working perfectly. How do I eliminate the re...
jerfurth
May 03, 2022Tutor
Thanks for the help and I have looked over page 11 of the manual. It appears the red light is normal.
michaelkenward
May 03, 2022Guru - Experienced User
Indeed. That is what plemans said in the first answer to your question.
