required_alias
Apr 28, 2023Guide
reestablish R6050 as AP
R7000 as router. R6050 as AP. R6050 is cabled to the R7000 with a run of ~60-70 ft. This setup has worked perfectly for years. Recently, the R6050 seems to have lost all contact to the R7000. De...
- May 02, 2023
Fixed it. I was changing to AP and then changing IP from 192 . . . to 10 . . .
Reversed that. Changed IP, then changed to AP. Seems to work perfectly. Thanks.
Apr 28, 2023Guru - Experienced User
Did you walk thru the setup wizard?
Default maybe admin and password for the log in.
Be sure to clear out all browser caches and saved PW profiles in the browser as well.
Was linked on how to setup a router in AP mode in this thread...
required_alias
May 02, 2023Guide
