nsxlane
Dec 29, 2020Follower
Reflashing Firmware on Netgear R7000p from MacOS
I have an R7000p that I installed an Express VPN custom firmware to. After uploading the new firmware, the router boots up and doesn't appear to be bricked, but. . . . I am unable to ping the rou...
Dec 29, 2020Guru - Experienced User
You'll want to look on the expressvpn site or the openwrt (what expressvpn is based off) site for help. they'll be the best able to help you with their firmware on using it or removing it.
this is for the official netgear firmware and not 3rd party firmware
