stabanelli's avatar
stabanelli
refurbished r7800, cannot register serial number to get remote readyshare access
Hi, I bought on Amazon a refurbished r7800 but I've realized that the serial number is already associated to the previous owner, therefore I'm stuck and cannot register the product to get either suppo...
  • ElaineM's avatar
    ElaineM
    Jul 18, 2017
    For ReadyCLOUD (previously ReadySHARE Cloud), you can just simply reset the device and create your own login.
