weedcoug's avatar
weedcoug
register a previously purchased router ac1750
I purchased a router for my parents. I helped them set it up and registered it for them. They ended up not using it and gave it back to me. I'd like to use it now and need to register it for myself. T...
  • weedcoug's avatar
    weedcoug
    Oct 26, 2019
    "Did they (or anyone) play with its settings?  If so, then a settings
    reset would probably be a good way to start."
    That's what I ended up doing and it works.  Thanks for all the suggestions.
