guyinsb
Jun 30, 2025Aspirant
Registration is required
It appears that registration is required in order to configure the router (to change the SSID, for example).
CrimpOn
Jun 30, 2025Guru - Experienced User
Physical access to the device is required to change the SSID. Registration is not.
Perform a Factory Reset on the device and configure it. One step in the process is to change the WiFi SSID/password (if desired)
- guyinsbJul 08, 2025Aspirant
Here is my experience. After a Factory Reset, I connected (via an Ethernet cable to a LAN port) to a Netgear R6400 (pre-owned, purchased from eBay) using a browser directed to 192.168.1.1. I encountered a screen requiring me to register. My attempt to register failed, because the router had been registered by a previous owner.
- CrimpOnJul 08, 2025Guru - Experienced User
My experience with Netgear routers has been that every time I perform a configuration, the "Register this device" screen pops up and I simply ignore it and go on to the next screen.
It might be useful to examine that screen carefully.
- FURRYe38Jul 08, 2025Guru - Experienced User
When you see the registration screen appear in the browser, just navigate way from it and go to 192.168.1.1.
