guyinsb
Jun 30, 2025Aspirant
Registration is required
It appears that registration is required in order to configure the router (to change the SSID, for example).
michaelkenward
Jul 01, 2025Guru - Experienced User
CrimpOn wrote:Physical access to the device is required to change the SSID.
Best done with a wired connection, a web browser and the graphical user interface (GUI).
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
Then:
How do I change my NETGEAR router password or network name (SSID)? - NETGEAR Support
Just another user with time on their hands.
