guyinsb
Jun 30, 2025Aspirant
Registration is required
It appears that registration is required in order to configure the router (to change the SSID, for example).
guyinsb
Jul 08, 2025Aspirant
Here is my experience. After a Factory Reset, I connected (via an Ethernet cable to a LAN port) to a Netgear R6400 (pre-owned, purchased from eBay) using a browser directed to 192.168.1.1. I encountered a screen requiring me to register. My attempt to register failed, because the router had been registered by a previous owner.
Jul 08, 2025Guru - Experienced User
When you see the registration screen appear in the browser, just navigate way from it and go to 192.168.1.1.
guyinsb wrote:Here is my experience. After a Factory Reset, I connected (via an Ethernet cable to a LAN port) to a Netgear R6400 (pre-owned, purchased from eBay) using a browser directed to 192.168.1.1. I encountered a screen requiring me to register. My attempt to register failed, because the router had been registered by a previous owner.
