MRKERN
Mar 28, 2022Aspirant
Remote power reset
Have Comcast modem & router Located in house 200 miles away. Unattended The router is used for monitoring all kinds of stuff in the house alarm water heating air-conditioning lights and that sort o...
Mar 28, 2022Guru - Experienced User
You have to be on site for any router to be able to reset it.
One can install a power timer and schedule a time frame on when the connected router could be powered OFF and back ON.
However if your having to reset or power cycle a wifi router, this means there is a problem that needs to be investigated and troubleshot to figure out the real problem as wifi routers are designed to be online constantly 24/7 and operate with out problems.
- MRKERNMar 28, 2022Aspirant
Thank you for the quick response.
I am an old electronic & telco guy
If I had a POT line, an answering machine and couple relay I could solve this problem.
NO app needed.
Thank you
- wcalifasMar 31, 2022Prodigy
you know I remember seeing a few years ago some timer thing with a plug was being sold so that your router could reset at night at a set time every day, not sure if they still sell these type of plug devices.
I see on amazon there's several ones they sell on their site. Just write router reset timer.
